Inner CV Joints... Replace 'em Both?
I have an '02 Boxster S with ~100k miles and basically no service history before I picked it up last summer. One of the inner CV joint boots is torn and I'm planning on replacing the entire joint since they're not that expensive. The other inner joint seems to be fine right now. With no history, and the fact that these joints aren't that expensive, is it worth doing them both? Also, I've seen recommendations to replace the axle assembly instead of just the joint, but that's quite a bit more expensive. Any compelling reasons to spend 10x the money to replace the full assembly instead of just the inner joint? Thanks!
Makes sense. Thanks for the reply.
