j911brick's Avatar
Strange Front Fan Issue
I have an odd issue with the left front fan. If you let the car warm up normally the left fan does not come on. If you turn on the A/C it sort of turn on and off at its own will. Then once the car is hot the fan will stay on even with the A/C off. Also: the fans come on when the needle gets to the right side of the zero, the temp drops a little, but not much.
What say you?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 06-02-2012, 08:39 AM
bar10dah's Avatar
Just based on your description, appears your driver side low speed fan resistor may be toast.
Old 06-02-2012, 09:33 AM
j911brick's Avatar
That is what I was thinking. Where exactly is it?
james
Old 06-02-2012, 09:45 AM
bar10dah's Avatar
Figure 3 at this link, it's attached to the frame behind the radiator (and behind that black plastic shield, so you can't see it in the pic).
Pelican Technical Article: Boxster Radiator Replacement and Cleaning - 986 / 987
Old 06-02-2012, 10:08 AM
bar10dah's Avatar
There are some troubleshooting steps you can take to narrow down your problem. If no one else posts them soon, I'll post it later.
Old 06-02-2012, 10:10 AM
j911brick's Avatar
Kewl; Thanks.
james
Old 06-02-2012, 01:38 PM
j911brick's Avatar
A friend of mine is a dealer tech and he is saying resistor as well. Did anybody ever come up with a radio shack solution?
james
Old 06-02-2012, 01:42 PM
