Certified Porsche addict
The Glademister's Avatar
Error code P0421?
I'm getting check engine light and my Durametric shows - P0421 Bank one catalyst warm-up efficiency below threshold. I'll clear it but it will come back after 20-30 miles. What's the prognosis doctor? Oh, this is on my '07 Cayman S with 58,000 miles.
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 06-24-2012, 12:47 PM
Paul V
paulv's Avatar
Here's some info to start with:
Possible fault causes
1) Oxygen sensors in front of and behind catalytic converter swapped (position in exhaust assembly)
2) Valve lift error
3) Aged oxygen sensor behind catalytic converter
4) Catalytic converter faulty (pre-catalytic conversion rate too low)
Doubt that item #1 is the cause unless someone was doing work on the car.
For item #3, try moving the Bank 1 sensor to Bank 2 and see if the fault also moves -- if it does, then the aft bank 1 sensor is defective. Also check wiring as these sensors are low to the ground.
Regards,
paul...
07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X
Old 06-25-2012, 04:43 AM
2) Valve lift error
Regards,
paul...
Thanks Paul. The whole "catalytic" term had me a little confused. I heard on another forum the cats and maybe the O2 sensors are covered under 8 year emission warranty. Going to give the dealer a call...
Old 06-25-2012, 06:34 AM
That's what I figured. Cats only covered. I'll be swopping the bank 1 and bank 2 O2 sensors.
Old 06-25-2012, 06:40 AM
Paul V
paulv's Avatar
Typically, it's the cats, the DME (PCM) and the PCM connector under the dash. The catch with the cats is that (as the old saying goes) cats don't commit suicide, they're murdered!! Which means they fail due to owner's foul ups!
Regards,
paul...
Old 06-25-2012, 08:00 AM
Update - I swopped the two post-cat O2 sensors and it hasn't thrown a code yet.
Old 06-28-2012, 09:06 AM
I have exactly the same problem and had all 4 sensors replaced. Everything was fine until about a month went past and the error code came back. It now comes back on every day or so. Also, I can sometimes hear a metal shaking sound when I rev the car slightly harder.
I'm starting to think I have a cat that is going bad...??
Old 08-02-2012, 01:29 PM
Author of "101 Projects"
Wayne 962's Avatar
Yup, the two oxygen sensors measure the efficiency and proper operation of the catalytic converters. Many times when they throw a code, it's the sensors themselves that have a problem. But in this case, if you hear rattling, I would suspect that the problem lies with the converter and the 02 sensors are giving you an accurate warning.
-Wayne
Old 08-02-2012, 11:45 PM
