Guest
Posts: n/a
Hello, does anyone have any idea what might have caused my 2003 Boxster to have a hole in the engine after only 75,000 miles?? My mechanic thinks moving metal parts probably caused the crack. I changed my oil much more frequently than the every 15,000 miles recommended by Porsche. I also did the 30,000 and 60,000 miles tune-ups. Aren't these engines supposed to at at least 100,000, if not 200,000 miles? Any guidance would be highly appreciated. I'm attaching a photo of the hole in my Boxster's engine block.
![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987 |
Can you take another photo, a little further back (more of the engine in view). An internal part failing and being thrown around inside can cause an issue like this. No telling how long an engine will last. Usually the joke goes, the least maintained engines last forever, while the engine treated well and maintained fail first. Saying that, I still maintain my vehicles properly and perform all preventive maintenance.
- Nick |
Well the timing chains act like conveyer belts. taking things
from the bottom front of the engine into the cam housings (heads) A bolt or nut might have worked its way loose and rode up the chain then played foozeball inside your cam housing until one of the cam lobes struck it into the side either one too many times -- or it was big enough to lodge against the lobe and sidewall and punch its way through. Downside is that the cam housing is matched to the cam cover (the camshafts journals are bored out together). You'll have to figure out where the bolt came from then source a replacement head and valve cover. I'm suspecting the finding of where the bolt came from maybe more intrusive. Any collateral damage? Alternatively you can source a replacement engine. mike Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
Your options are here. And yes, many Boxster engines go 200k but think of failure frequencies as a bell curve, some fail on either end.
It could be just bad casting, a better pic of it would help. From here it doesn't look stressed from the inside.
---------------------------------------------------------------- 98 Boxster 87 560sl 04 S2000 |
If that is the Cam cover in the pic you may be able to find a used replacement cover that fits acceptably with the head & cams. You will need to do a trial assembly & check the cam bore alignment & clearance. However the engine will need to be completely disassembled, throughly cleaned & inspected for excessive wear of all parts & find the pieces that caused the damage!
i agree with the suggestions offered by others. if my own car developed ahole like this i would remove the engine, or have someone do it, and conduct a thorough inspection and disassembly as needed to get to the cause. At that point an assessment of repairs and options can be formulated
Good Luck |
