Any idea what this connector is for ???
Found it in the shifter console. the following numbers where listed 1-929 529, AMP 1-828 8191, BMW 1-378 134.
P. Kirby
2004 Boxster S 550 Anniversary Edition
2011 Acura MDX
2012 Mini Countryman S
Old 10-21-2012, 07:17 AM
JFP in PA's Avatar
Factory cell phone...............
Accrochez-vous bien de vos rêves..........."
Old 10-21-2012, 07:31 AM
s_wilwerding's Avatar
The nice thing is that, if you want to integrate your garage door opener or another accessory, you can pull 12 V constant and switched power off of that plug. I added a garage door opener button to my center console using that for switched power.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 10-22-2012, 05:09 AM
Any idea where I can find a wiring diagram for this connector
Looking to find the power and ground, may use for my next sat radio install.
P. Kirby
2011 Acura MDX
Old 10-25-2012, 09:08 AM
Where was it? Did you have to pull the entire console to get at it? Be nice to know if it's switched 12V or not!
Tom Coradeschi
03 Boxster
Old 10-26-2012, 05:12 AM
If you pull out the console piece in front of the shifter (where the GT3 console would go), it's usually just sitting right inside there.
Steve Wilwerding
Old 10-26-2012, 05:30 AM
2001 Boxter S
wonder if one can get the other side of this connector ?
Old 10-26-2012, 09:07 AM
It is switched 12v. I've tapped my radar detector into it.
Old 10-27-2012, 04:54 AM
which wire is the power, which is the ground ?
P. Kirby
2011 Acura MDX
Old 10-28-2012, 07:07 PM
