UNYboater's Avatar
Ignition Switch Questions
After reading through Project 86 & several threads on topic, I still have a couple questions. (I posted them here but figured putting it in the main forum might get more responses)
Here's my situation: '01 S & I don't believe I have the upgraded mechanism. Yesterday, my key was tough to get into the slot. When in, it turned & the car started but the spring didn't pull it back from 'Start' to 'Run' like it had before. Also, when shut off, I had to hold it all the way to the detent that allows the key to be removed (& the electronics to shut off). It's like the springs let loose & the detents are off.
Are the springs & detent mechanisms in the replaceable portion of the old mechanism (Part # 4A0-905-849-B-M56 on Pelican)? Or are they in the main mechanism meaning that I need to replace the whole thing?
Either way, it appears to me that I can reuse the existing tumbler & keys...correct?
Thanks!
2001 Boxster 'S' : even my motorcycle was a 'Porsche', '03 Harley V-Rod
1997 Boxster Base; my (former) DD, now resting in peace
1998 BMW 323iC; my son's DD.....now sold
1985 (early) 944; gone now, but not forgotten
1974 Fiat X-1/9; my first mid-engine car
Old 07-23-2013, 08:33 AM
hi there,
this is what happened to my 99. do all your electronics work? I was able to just replace the switch and it took about an hour.
Roy
Old 07-23-2013, 09:58 PM
UNYboater's Avatar
Originally Posted by royroger66 View Post
hi there,
Roy
Yes, everything electrical is working as it should. It's just the springing isn't correct & the clicks aren't right.
Old 07-24-2013, 08:03 PM
I've had the same issue with my switch but it also didn't shut off my car when I took the key out, you can still reuse the tumbler and keys. I just got my switch at Autozone for around $25( with employee discount) it was locally here. installed it and it works like a charm! Plus lifetime warranty, can't beat that! But if you want to go OEM I'd go with what they have here.
Old 07-24-2013, 09:42 PM
UNYboater's Avatar
We need the car this weekend (my son is getting married!) so I checked my local Autozone; they STOCK the switch! $39 (not an employee) so it was more than here on Pelican but I installed it in about 30 minutes when I got home & it's perfect!
I think I'll order one here as well & keep it in the frunk for when this one dies!
The little screwdriver from my Craftsmen set worked great to undo the set screws & my 'head-light' (forehead-mounted LED flashlight) made it possible for me to see!
Old 07-25-2013, 07:42 PM
