doc (guest)
Guest
Posts: n/a
would a MAF sensor control air pump function My air pump works if i SEND CURRENT TO IT but left to its own devices it fails to come on in a timely fashion giving me a P0410
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-15-2013, 06:29 AM
Nick at Pelican Parts's Avatar
No, the MAF does not control the air pump. You might have a faulty fuse or relay. i would grab a wiring diagram and test the circuit for the air pump.
- Nick
While I don't know the exact parameters, the secondary air pump only operates for about 90 seconds when the engine is started cold and the outside air is below a certain temperature.
Old 08-15-2013, 07:04 AM
Paul V
paulv's Avatar
Originally Posted by thom4782 View Post
While I don't know the exact parameters, the secondary air pump only operates for about 90 seconds when the engine is started cold (-10 deg C to 42 deg C)and the outside air is below a certain temperature(-10 deg C to 42 deg C).
Parameters for future reference (DME 7.2).
Regards,
paul...
07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X
Old 08-15-2013, 08:06 AM
Thanks for the info. -10C to 42C is roughly 14F to 105F. I guess this means that the secondary air pump will operate if the engine is cool or cold for the most part. For lots of the US, the outside air temperature is between the range limits on most days.
Old 08-15-2013, 08:39 AM
Paul V
paulv's Avatar
I don't know if Porsche is doing this for the newer cars but I've seen cases (U.S. cars) where SAI kicks in when the engine is idling for a long time because the "pup" cat and upstream O2 (actually, A/F ratio sensor among other names) have cooled down enough to cause the feedback function to go open-loop (also turns on the O2 sensor heater when this happens). With emission requirements getting more strict, I'm also seeing (from many OEMs) the downstream O2 sensor being part of that feedback loop which it wasn't when it was implemented for OBDII (1996) to check on the oxygen storage in the cat.
Times are changing and things are getting more complicated...............
Regards,
paul...
Old 08-15-2013, 10:37 AM
