Guest
Posts: n/a
would a MAF sensor control air pump function My air pump works if i SEND CURRENT TO IT but left to its own devices it fails to come on in a timely fashion giving me a P0410
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
No, the MAF does not control the air pump. You might have a faulty fuse or relay. i would grab a wiring diagram and test the circuit for the air pump.
- Nick |
While I don't know the exact parameters, the secondary air pump only operates for about 90 seconds when the engine is started cold and the outside air is below a certain temperature.
Paul V
Regards, paul...
----------------------------------------------- 07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X |
Thanks for the info. -10C to 42C is roughly 14F to 105F. I guess this means that the secondary air pump will operate if the engine is cool or cold for the most part. For lots of the US, the outside air temperature is between the range limits on most days.
Paul V
Times are changing and things are getting more complicated............... Regards, paul...
Thread Tools | |
Rate This Thread | |
