Clam shell weather seal "clip"?
2006 Boxster base: I have a weather seal on the bottom of the clam shell that has come loose. It is on the driver's side and i must be missing a clip to hold it on. Does anyone know what they are called and where they can be obtained? Or, have ideas on how to secure the seal back in place? Thanks.
I have the same car, and every now and then the same problem. I'm trying to remember a clip, but I want to say that the rubber has a "kerf" that slides on, and the stiffness of the rubber holds it there. I guess you could try some 3M weatherstrip glue, but I haven't gone that route yet...
U-Clamp Edge Protection
I found the part 99950760009 is the U-Clamp for the Clamshell's protective edging.
