1999 Boxster Rough Idle / stalls ( see video)
I just bought the car which was sitting in the garage for over a year maybe more 121k miles. The problem:
It starts hard and drops RPM / stalls also doesnt rev more then 3k need to keep the pedal pressed to run.
CEL is on
see video ( sorry its upside down)
The previous owner claims to have changed
spark plugs
ignition coils
air oil separator
cleaned fuel injectors
new battery
I ran a diagnostics using Porsche scanner it says
1) Camshaft position sensor 2
2) Mass air flow sensor
3) Misfire on Cylinder 4,5,6
where do I start? COILS / SPARK PLUGS?
thanks
Old 06-12-2014, 10:22 AM
p1397 Fault code 113 camshaft
p0102 code 115 mass air flow
p0300 code 75 miss fire
p0306 code 68 cylinder 6
p0304 code 66 cylinder 4
p0305 code 67 cylinder 5
Old 06-12-2014, 02:01 PM
If it isn't some kind of catastrophic issue I would start out with a smoke test and look for vacuum leaks.
Old 06-12-2014, 06:39 PM
is there a DIY for smoke test
Old 06-12-2014, 07:42 PM
I was suggesting a smoke test because I tend to think you have a leak someplace.
Without a smoke machine you can try and visually look for leaks. Based on the way yours is running either you have a really big leak or something else really wrong. One time I took a plastic slurpee cup and cut it so I could duct tape my shop vac hose to it and then I connected it to the intake where the MAF would connect. I then could listen for leaks.
You could also have a camshaft sensor problem too.
I am by far not a 986 expert though. Most of my car repairing exp is on BMW.
Old 06-13-2014, 01:44 PM
Anyone on this read - it stalls / misfires alot
p1307 Fault code 113 camshaft
Old 06-20-2014, 10:32 PM
wad wad is offline
Vacuum leak or possible failing crank position sensor.
After I changed my CPS I had misfire codes like crazy and once I ran it for a bit they cleared once the computer saw where the crank was at.
Old 06-21-2014, 09:38 PM
OK I changed the Camshaft with a after market camshaft of ebay - it looked different i still tried it out - it started a little better then before but still camshaft error code
when I unplugged the Camshaft sensor altogether it wouldnt even start
also the swish / screeching sound is the pulley
I ordered the OEM camshaft to make 100% sure.
Now, lets say the new sensor is OK and i still get the Camshaft error code same bank what would that mean?
and I dont have a Vacuum leak
thanks
Old 06-21-2014, 09:44 PM
If you don't have a vac leak, you need to do a compression test on each cylinder as your next step.
Old 06-22-2014, 05:18 AM
so regardless of the misfire I still do a compression test? if the compression comes out bad that side is messed up right?
Whats the reading for a cold engine compression.
Old 06-22-2014, 11:02 AM
I had an engine that had a bad intake valve seat which resulted in 0 PSI on one cyl.
This also messed up the vacuum too since the thing was pushing air back to the intake.
Like you I was chasing all sorts of problems, but once I ran the compression test and found the dead cyl I finally found the problem.
Run your test and see what you come up with. You want to see at least 150 psi (don't quote me on that number. I am guessing based on other engines)
Old 06-22-2014, 01:09 PM
