Radio, dash, windows staying powered after taking out key
When I take the key out of my 2001 Boxster S, the radio stays on and everything else still has power to it.
I though I remembered the key switching popping out a bit when removing the key in order to turn it off, but now it doesn't and it feels a bit stiff.
After a few minutes of wiggling or shaking the key violently when its 95% pulled out, I can get everything to turn off properly, but it is definitely a pain.
Should I try lubricating with graphite or something else? Otherwise what part do I order and instructions on the install please?
Thanks,
Old 07-14-2014, 01:01 PM
UNYboater's Avatar
The electronics portion of the key switch is a fairly easy replacement & will probably fix this issue. I'd recommend ordering it from Pelican (Part # 4A0-905-849-B-M56 I believe) but I was stuck and AutoZone had one IN STOCK that was correct (they listed it for Audi). It's probably the quality of the $12 here for twice that, so order the $32 if you can.
2001 Boxster 'S' : even my motorcycle was a 'Porsche', '03 Harley V-Rod
1997 Boxster Base; my (former) DD, now resting in peace
1998 BMW 323iC; my son's DD.....now sold
1985 (early) 944; gone now, but not forgotten
1974 Fiat X-1/9; my first mid-engine car
Old 07-15-2014, 09:56 AM
