john d (guest)
Guest
Posts: n/a
The old cluster was burnt so I had to replaced them. Everything works with the new cluster when I test them including all lights, oil, speedometer...with the exception of turn signal and hazard/warning lights. But it's weird when I turn the hazard light on and flip the turn signal....it's working, but not by itself.
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-08-2014, 05:33 PM
Nick at Pelican Parts's Avatar
Ok, thanks for the info.
I would think the hazard switch is faulty. The cluster is only bulb lit indicators, other than that it doesn't do anything for the turn signals. You can check the output of the turn switch tot he luster when you activate the signal, look for battery positive.
- Nick
