herb (guest)
Guest
Posts: n/a
I have a real poblem here, I have changed the following on my Boxster 01, fuel pump with the crankshaft position sensor,and the car when it is at idle it behave as though it wants to cut off ,does this have to do with the fuel injectors at this point
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Engine Sensor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 09-02-2016, 06:28 AM
Nick at Pelican Parts's Avatar
Is the check engine light on or flashing when the problem is present? Sounds like an engine misfire. I would check spark, fuel and compression on all cylinders.
- Nick
