Filter Question
I was changing the filter on my '99 Boxster today and noticed a spring loaded valve in one end of the old filter. The filter fell out of the base when I removed the canister, so I can not tell which end it belongs in.
I assume that it is a pressure relief valve for the filter to circulate oil if the filter is clogged. I that correct? It appears that it needs to go in the bottom of the cannister. Is this correct?
David Nolen
'99 Boxter
'70 911
Old 09-04-2016, 12:42 PM
JFP in PA's Avatar
Yes and yes.
Accrochez-vous bien de vos rêves..........."
Old 09-04-2016, 01:12 PM
Thanks!
David Nolen
Old 09-04-2016, 02:19 PM
