It'll be legen-waitforit
Something's leaking
So while I was changing the oil on my 06 Cayman I noticed the half shaft on drivers rear showed signs of oil/fluid. I assume it would be the half shaft rather than the wheel bearing, but the rubber looks good and the clamp was tight.
Is this a do it yourselfer job without a lift? What are the chances it's the bearing versus the drive shaft? Now my dilemma, I want to change out the suspension so should I bite the bullet on buying it and tackle it all at the same time? What say you? Bob
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo Last edited by stealthn; 10-29-2015 at 07:19 AM.. |
