Guest
Posts: n/a
Hi, this morning i start the boxster 2.5 1998 but all i could hear is the starter but the motor run like for one second and did stop after, only the starter seems to go on... what can it be?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume, quality and engine compression. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick |
