Guest
Posts: n/a
I have a 2000 Porsche Boxster S with codes P1128 and P1130. Do I need to replace the O2 sensors? If so, which ones? Thank you much.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Oxygen Sensor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
These codes are more commonly cause by a faulty mass air flow sensor.
- Nick |
– Incorrect signal from MAF sensor
– Intake air system leaking – Fuel pressure too low – Volume supply of fuel pump too low – Fuel injectors fouled – Exhaust system leaking |
On my 2000S I had similar issues with CEL/fault codes about knock and 02 sensors. Also right bank rough running. One was also about a faulty heater on the O2 sensor. But overall the car seemed to run OK. It turned out the clamps on the intake manifold rubber boots were loose causing a vacuum leak. Once tightened the car idled better and had better smoother acceleration.
