Guest
Posts: n/a
My Boxster is a 2000 2.7L. You can see in the photo the serial number for my cluster. The far left socket on the bottom row is the cruise control indicator on this cluster. My owner's manual places it within the speedometer dial. I'm glad I found it before I began disassembling the cluster!!! Of course, it's a Saturday and the parts department is closed. Now I have to figure out how to remove the trunk release assembly to run the wires back to the computer. Any ideas?
![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Instrument Cluster Bulb Replacement - 986 / 987 |
if running wires from the trunk, remove the trim panels, run the wire in loom and secure it using sire tires.
- Nick |
