andrew (guest)
Guest
Posts: n/a
Hi, I have a 2004 boxster that has the low beams programmed as the DRL's. Upon starting the car, both lights will come on but the drivers side will always go out shortly after. Sometimes it only lasts 5 minutes, other times it will stay on for 20-30 minutes. If I start the car up again, it will always come back on again, however. Any suggestions for what the problem might be? bulb? ballast? switch?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Headlamp Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 03-02-2016, 06:58 AM
Nick at Pelican Parts's Avatar
I would assume ballast. Try swapping parts from the working side to the non-working side to rule them out.
- Nick
