turboflyer's Avatar
lintronics auto leveling trouble shooting
Really at a loss. 2001 Boxster S. Would appreciate any help. Have searched high and low. No pun. The headlights dip as they should when ignition turned on. However they do not adjust when high beam is actuated. I lifted the car and took the front sensor arm off and moved it up and down with no movement in the lights. Since I can not find the information to trouble shoot the system I am at a loss. Sure Hope there is some one with the needed knowledge. Thanks.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 11-28-2016, 07:51 PM
Porsche Boxster Litronic Headlamp Kit Upgrade - 986 / 987 (1997-08) - Pelican Parts Technical Article
Here are the instructions for retrofitting the litronics to a car that didn't come with them from the factory. Since the headlights dip when you turn the ignition on, the motors in the lights are likely to be OK. I would check the electronic control unit. You may have to just buy one and swap it out. I see them on Ebay and they aren't too expensive. I'm sure they would be much more from a dealer.
Good luck.
Old 11-29-2016, 04:12 AM
