Aviator 912 (guest)
Guest
Posts: n/a
My Boxster was registered on the road beginning of Jan 2001, so I guess was being built in 2000. How do I find out which version of the wiring cluster options to use? As per previous comment assume the connector is the Grey one, not the blue or Green?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster On Board Computer (OBC) Upgrade and Turn Signal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 10-21-2017, 09:10 AM
Nick at Pelican Parts's Avatar
Boxster 2001-2004
Connector Pin #2 Gauge Cluster Pin #23 Select Mode Down
Connector Pin #3 Gauge Cluster Pin #22 Speed Alert/Gong
Connector Pin #4 Gauge Cluster Pin #21 Select Mode Forwards
Connector Pin #5 Gauge Cluster Pin #24 Select Mode Backwards
- Nick
