Guest
Posts: n/a
My Boxster was registered on the road beginning of Jan 2001, so I guess was being built in 2000. How do I find out which version of the wiring cluster options to use? As per previous comment assume the connector is the Grey one, not the blue or Green?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster On Board Computer (OBC) Upgrade and Turn Signal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
Boxster 2001-2004
Connector Pin #2 Gauge Cluster Pin #23 Select Mode Down Connector Pin #3 Gauge Cluster Pin #22 Speed Alert/Gong Connector Pin #4 Gauge Cluster Pin #21 Select Mode Forwards Connector Pin #5 Gauge Cluster Pin #24 Select Mode Backwards - Nick |
