Doug (guest)
Guest
Posts: n/a
I have a 1999 Boxster Tiptronic with a leaky seal where the axle exits the differential. Must remove the stubb axle to change the seal. Can this be done with the engine in the car even if you have a Tipronic?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Differential / Manual Transmission Fluid Change - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 10-21-2017, 09:07 AM
Nick at Pelican Parts's Avatar
Yes, stub has to come out. yes can be done in car.
- Nick
Doug Steinel's Avatar
Tiptronic?
Nick,
thanks for the quick response. My local well regarded Porsche garage is telling me the seal in the stubb axle can't be replaced without removing the transmission and want $1600 for replacing that seal. I am glad to hear you think it can be done without removing it. Anyone else do this job with a Tiptronic successfully.
77 911, 3.0L
Old 10-22-2017, 02:32 AM
Jeff Alton's Avatar
Is this the passenger side seal? We replace at least one per month without removing the gearbox.. Find a new shop...
Cheers
www.turn3autosport.com
Old 10-22-2017, 07:25 PM
Yes, it is the passenger side seal.... what is a ballpark figure one should pay to have this seal replaced on passenger side?
77 911, 3.0L
Old 10-23-2017, 02:45 AM
Jeff Alton's Avatar
Less than 2 hours labour to replace, plus seal...
Old 10-24-2017, 09:32 PM
How about he driver's side seal? Can that be done with engine/tranny in the car?
Doug
77 911, 3.0L
Old 10-25-2017, 05:08 AM
Jeff Alton's Avatar
Yes
Old 10-25-2017, 09:30 PM
Jeff,
I really appreciate your input on this. I am told that the driver's side stubb axle is longer than the passenger's side one. And that it means you need to drop the drivetrain to get that longer stub axle out to get at that seal. Have you done the driver's side without RR of drivetrain?
Doug
77 911, 3.0L
Old 10-26-2017, 01:15 AM
Jeff Alton's Avatar
You may need to remove the axle, but just undue the upright to pull the axle. Would never drop a drive train to replace a seal like that..
Cheers
Old 11-08-2017, 04:28 PM
