Go Back   Pelican Parts Forums > Regional Forums > Canada
engine upgrade 2.7 to ???
Hi
Looking for info on upgrading my 2.7l to 3.2/3.6l.
What would you do?What engine are for sale in Canada?
My 2.7 is having stud problems..Is it worth rebuilding it
with the stud fix or am i wasiting my time on this block?
Mark
Old 06-11-2006, 03:43 PM
djpateman's Avatar
It depends on how much money you want to throw into a new engine. Casesavers should make a permanent fix of the pulled studs.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 06-11-2006, 06:50 PM
Counterclockwise?
There's a 3.6 for sale in TO.
Rod
1986 Carrera
2001 996TT
Old 06-12-2006, 12:35 PM
What did you do about this engine? I have a really good 3.0L from a 1980SC for sale in the London Ont area.It has 107k mi on it Was dismantled about 15000 ago for a broken stud and pressure fed tensioner update. I am a retired class A technician and can install. johnsjmc@sympatico.ca 519 768 3133.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 09-02-2006, 05:14 PM
I personally wouldn't take a 2,7 magnesiun case and take it to 3.2/3.6L. My experience is that although case savers will solve your head stud issue any number of perimeter studs may pull if not inserted, Especially the stud between the crank and intermediate shaft. If your engine once had thermal reactors I would be very careful with it. The material tends to become very brittle with age. You'll certainly need to get the case checked for straightness. I am in the process of rebuilding a 2.7. I assembled the case 3 times due to the perimeter studs pulling.
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 09-13-2006, 05:52 PM
