Go Back   Pelican Parts Forums > Regional Forums > Canada
2porscheguy's Avatar
MSD6A ignition upgrade..is it worth it?
Hi fellow Canadian Pelicans! Before I perform a search on the 911 Technical Forum, I thought I'd post this here first.
Is it worth upgrading to the MSD6A ignition in a '80 911SC?
Thanks for your input!
Cheers!
Alex
Alex
'80 911SC Targa
'06 997 C4S Coupe - SOLD
'07 997TT Coupe
Old 11-22-2012, 03:03 PM
6al
I was very happy after replacing the permatune with a 6AL in my 930. In my application, it was a very good upgrade. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 11-23-2012, 03:39 PM
haycait911's Avatar
yup. I run 6AL's in everything.
Old 11-24-2012, 12:17 PM
Bland
unclebilly's Avatar
The only thing better is mega jolt. If you are ever considering twin plugging, mega jolt is the ONLY way to go.
Old 11-24-2012, 05:10 PM
rookie blues
midnite blue 88's Avatar
Send a message via MSN to midnite blue 88
If every car in nascar runs msd then it has to be a proven product .And if you find a box that does not work just send it back to the factory and they will fix it for a small fee of about 40 bucks.
Old 11-27-2012, 09:47 PM
haycait911's Avatar
if you put one in, keep your eyes open for another. I have a spare I keep in the front. IF there's a problem, two minutes to plug in the spare and I'm on the road.
Old 11-27-2012, 09:57 PM
andrew15's Avatar
If you go the MSD route, but it from a known source - there are actually cheap Chinese counterfit ones out there.
AM
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 11-28-2012, 06:49 PM
Bland
unclebilly's Avatar
There are millions of Ford cars and trucks running around with EDIS, the basis of the megajolt system. The megajolt box is only the controller that allows you to setup your timing maps. The rest of the parts are Ford, unless you want to use a different coil pack.
Old 11-28-2012, 07:41 PM
Thanks for the input guys.....I'll be adding this project to a growing list of DIYs for this coming spring!
Alex
'80 911SC Targa
'07 997TT Coupe
Old 12-10-2012, 11:29 AM
