Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
R-57 14 Mini Convertible - Clunk when going over curbs
I had a bad clunk when going over a driveway entrance or curb, anytime that the car was twisted axially.
I was certain it was coming from the rear, thought sway bar link or sway bar bushing.
Ordered parts - links and bushings.
Tore it apart - all looked good, replaced bushings, reused links.
Still clunked.
Crawled around underneath and tightened everything I could see connected to the suspension.
I found a loose bolt holding a long metal bar which runs from the center of the rear suspension assy to the left side under the driver's door.
The bolt under the drivers door was about 1/2 turn loose.
Tightened it and clunk is gone.
Old 07-14-2018, 01:10 PM
Administrator
Luccia at Pelican Parts's Avatar
Good find! I would've also thought your LCA's might have been a bit worn. Glad you found your issue!
Old 08-13-2018, 05:24 PM
