Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Kwasi (guest)
Guest
Posts: n/a
Purchased a filter and level sensor kit and pulled the tubes out of the tank. Is the black tube supposed to be attached to anything in the tank?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Filter Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 07-22-2017, 04:58 AM
Nick at Pelican Parts's Avatar
I don't recall hose colors and connection specifics as they apply to them. If you share a few photos I may be able to give some insight.
- Nick
Good question. I was hoping that someone could help identify all the hoses and how they work between the filter and pump. Do the hoses from the filter go to the pump? How does it all set up in the tank?
cheers, RKL
Old 04-10-2020, 01:17 PM
