Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
FRS FRS is offline
300/present trouble code
I am getting the following codes after replacing the cross engine water pipe and replacing the vacuum unit.
The battery was disconnected for this work.
300/present - Exhaust camshaft sensor, electrical short to B+
2C58/present - Charging pressure control: Switch-off as consequence.
I have checked the wires from the cam shaft sensors - no shorts
Switched sensors cleared codes problem returns.
both cam shaft sensors were replace last month while fixing a VANOS issue.
Any help would appreciated.
Old 06-24-2020, 11:45 AM
