Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Nick (guest)
Guest
Posts: n/a
I just bought new strut mounts and I am installing them this weekend. Is it possible to compress the spring, use an impact driver on the 1 nut on the strut then the 3 nuts on the strut tower and replace the strut mount without any further disassembly? It looks liek there is enough room in figure 4 after lowering the assembly.
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-28-2013, 08:40 AM
Nick at Pelican Parts's Avatar
No, I would advise against it. You can easily mis-align something and end up worse off that before you started,
- Nick
