Guest
Posts: n/a
Where is the 3rd bleed screw you refer to on the R50 motor? I found the 2 you show in pics 16 & 17 but you don't mention where #3 is. Please respond. Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Coolant Change |
There are two bleeder screws you should open. One at the hose on right side of engine and one at the thermostat housing. This applies to supercharged and normally-aspirated models.
- Nick |
