Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Johnny_Phx (guest)
Guest
Posts: n/a
I have always supported the front of my R53 with jack stands under the front subframe. I've done this MANY times and it seems to work well. Is this a bad idea?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Jacking Up Your MINI
Old 05-07-2013, 05:23 AM
Nick at Pelican Parts's Avatar
As long as you are on a solid piece that will not be damaged and the jack stands sit straight and even. However, MINI recommneds using the jack pads to support the vehicle, so that is my preferred method.
- Nick
