Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mark (guest)
Guest
Posts: n/a
Thank you for the article. It was invaluable. I did find that it is not necessary to remove the starter, only the two mounting bolts.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Replacement
Old 05-07-2013, 06:05 AM
Nick at Pelican Parts's Avatar
Thanks for the tip. You can hang the starter of out the way when removing the trans.
- Nick
