Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Juan (guest)
Guest
Posts: n/a
Thanks for your great info, i just replaced both bushings with frame and i found that to remove and re-apply the bushings on the control arm it will be easier and faster if you use a pully system, it took me 10-15 minutes.
And to loosend the bolts use a wrench extender for the driver side.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Control Arm Bushing and Ball Joint Replacement
Old 05-07-2013, 06:13 AM
Nick at Pelican Parts's Avatar
Thanks for the additional information.
- Nick
