Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
mxli66 (guest)
Guest
Posts: n/a
Hi, My window doesn't work up or down I do everything but I can't lower the window to removed the sprockets.
How I lower the window manually?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Window Regulator Replacement
Old 05-08-2013, 04:48 AM
Nick at Pelican Parts's Avatar
If you can access the window motor, disconnect it fromt he window regulator, then push the window down by hand.
- Nick
