Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
John (guest)
Guest
Posts: n/a
I have this issue: got Bilstein HD shocks and HR lowering springs, green. Fig 9 the Bilstiens are not angled, just a flat surface, special there washer doesn't make sense. I have lived with rear rattle for a long time and I can't take it. Want to get it right. Ideas? Thanks for responding!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Rear Shock and Spring Replacement
Old 05-15-2013, 04:11 AM
Nick at Pelican Parts's Avatar
If the washer in figure 9 isn't secured by the upper spring retainer, you may have a rattle. I would check that it all went back together correctly. If your struts looked different, check with the manufactuer to see if there are installation instructions that vary from ours.
- Nick
