Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Chad (guest)
Guest
Posts: n/a
Can you not use a vacuum bleeder on the slave cylinder?
I ain't seem to suck fluid out from the line.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-19-2013, 06:21 AM
Nick at Pelican Parts's Avatar
Yes, you can use a vacuum bleeder.
I like to fill the reservoir, then open the bleeder and let it gravity bleed for a while. Then bleed the normally. If it gives me trouble bleeding I will usually pressure bleed it.
- Nick
