Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Bartman (guest)
Guest
Posts: n/a
Great job on this article! This really helped me out alot! Now that I have the window actuator replaced and working fine, I have to lift the toggle switch up to lower the window and down to raise the window. Any suggestions?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-14-2013, 05:08 AM
Nick at Pelican Parts's Avatar
I have not run into this problem. There could be a wiring issue with the new motor, the polarity could be switched. I would check with MINI to see if programming wil remedy the issue. As mentioned by another user below, he has heard this is a software issue.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
