Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
rich (guest)
Guest
Posts: n/a
Why does this happen? - I have a suspect pump and/or filter
Take the upper cover and carefully line up the tabs on it it can only go in one way with the tabs on the lower filter housing. Take care to make sure the upper cover is directly seated on the filter element. If it isn’t, the car won’t start.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-26-2013, 03:54 AM
Nick at Pelican Parts's Avatar
If it is not lined up, there will be an internal leak int he fuel tank, along with a drop or loss of fuel pressure.
- Nick
