Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Edison (guest)
Guest
Posts: n/a
what if i forget to line up the indentation like in figure 13
i just realized I might of forgot on one side, will there be any ill effects?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-27-2013, 03:01 AM
Nick at Pelican Parts's Avatar
That helps to get the spring in the correct position.
It depends on where it landed. The cap may not be all the way down on the upper spring bushing. Which could make it crooked when you tighten it. I would go back and realign the top cap.
- Nick
