Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
gsmetz (guest)
Guest
Posts: n/a
should I change out the timing chain and guides at 100,000 Ks on my mini cooper R56 chilli , year 2007 , hatchback ?
Even so , if it is in good condition should I change the timing chain and guide out anyway ? Is it recommended by BMW Mini to change it out at 100,000 Ks ?
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-03-2013, 04:58 AM
Nick at Pelican Parts's Avatar
The engine used in your vehicle has a tendancy to stretch the timing chain. Especially if the engine oil is run low a few times. If you are performing routine maintenance or repairs related to the timing chain and guides, I would replace them. If the chain is not noisy, it maynot be necessary.
- Nick
Old 09-03-2013, 04:59 AM
Timing chain replacement
Hi there
Can you tell what parts and part numbers I need to do a timing chain change out , I know I need a chain and guides .
This is so I can order all the parts from pelican parts to do this timing chain replacement job .
Cheers Gary Metz
Old 09-09-2013, 09:59 PM
