Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
weaselciuy's Avatar
Hello,
The article says "will need four M6x50 bolts" but the picture has "along with 4 new M8x35 bolts" .
Which one is the right now? Im not good with bolts .
Thank you
This post was auto-generated based upon a question asked on our tech article page here:
N-ai Treaba !!!
Old 09-09-2013, 05:00 AM
Nick at Pelican Parts's Avatar
You'll want to use M6 x 50mm bolts. Be careful when tightening. The factory bolts have a sleeve that prohibit them from being overtightened. The replacement bolts if overtightened may crack the valve cover.
- Nick
