| Registered User |
			Hello,  The article says "will need four M6x50 bolts" but the picture has "along with 4 new M8x35 bolts" . Which one is the right now? Im not good with bolts . Thank you __________________ This post was auto-generated based upon a question asked on our tech article page here:
				__________________ N-ai Treaba !!! | ||
|  09-09-2013, 04:00 AM |
| Moderator Join Date: Jul 2012 Location: New England
			You'll want to use M6 x 50mm bolts. Be careful when tightening. The factory bolts have a sleeve that prohibit them from being overtightened. The replacement bolts if overtightened may crack the valve cover.  - Nick | ||
