Guest
Posts: n/a
I am getting lukewarm heat inside my 2003 Mini S. I have had the thermostat replaced. All hoses have been checked and they are producing heat, but very little inside cabin. The car has Climate Control system. Suggestions?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
If there is hot coolant going into the heater core and no heat. The heater core may be plugged. Check if the outlet hose is hot or cool. this will be a good indicator of the flow of coolant through the heater core.
- Nick |
