Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Slomos (guest)
Guest
Posts: n/a
I am getting lukewarm heat inside my 2003 Mini S. I have had the thermostat replaced. All hoses have been checked and they are producing heat, but very little inside cabin. The car has Climate Control system. Suggestions?
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-22-2013, 05:24 PM
Nick at Pelican Parts's Avatar
If there is hot coolant going into the heater core and no heat. The heater core may be plugged. Check if the outlet hose is hot or cool. this will be a good indicator of the flow of coolant through the heater core.
- Nick
