Guest
Posts: n/a
my lines refuse to bleed. i replaced the slave and the feed line to it, my slave seal was shot. first i tried vacuum bleeding with no luck, then gave up and ordered the pressure bleeder. no luck, then i tried to use both at the same time, still nothing. im giving up and ordering the master cylinder. there has to be a mechanical issue going on. not loving it
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The master may be faulty, I would assume that if it will not build pressure to bleed.
- Nick |
