Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
shrevemini (guest)
Guest
Posts: n/a
When reading the last part of the fill process. You install the t55 plug in, but leave the plug out of the pan. Start the car. Then cycle thru the gears. Shut off and fill again till it comes out of the drain hole?
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-19-2014, 12:04 PM
Nick at Pelican Parts's Avatar
Yes, the plug for the inspection tube stays out until you are done filling it.
- Nick
