Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
shrevemini (guest)
Guest
Posts: n/a
I did my transmission this weekend. I changed the filter. I started the fill process. At 2 quarts it started to come out the overflow. Is this right. I know im level. Any help would be great. John.
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-19-2014, 12:07 PM
Nick at Pelican Parts's Avatar
Sounds like not enough fluid to be full. Did you measure what came out of it? I find that helps when refilling, at least you can get the level close on the first try.
- Nick
