Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
MikeM (guest)
Guest
Posts: n/a
Excellent write up. Quick question on the gap adjustment. No matter what I do I cannot get the window to seal tightly against the outside seal fig 39 adjustment. At this stage I am considering adding some washers to the top mount bolt to go between the regulator and the door to push it back a little.
Thoughts?
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-23-2014, 07:01 AM
Nick at Pelican Parts's Avatar
I would not add the washers. The regulator may not be going up enough. Is the glass adjust correctly? (fig 40)
- Nick
