Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Gary (guest)
Guest
Posts: n/a
My passenger side window stopped working so I pulled it apart with your detailed procedure, but I found a discerpancy - my regulator/motor assemply did not have the adaptor plate shown in figure 29. Is this possibly an omission by the factory or a subsequent incomplete repair? The failure seemed rather dramatic - the steel cable pulled apart. Might this have been caused by incorrect installation? If I need this adaptor plate, where can I find one? Thanks Gary
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-27-2014, 08:24 AM
Nick at Pelican Parts's Avatar
The cable failing that way is pretty standard. Your vehicle may not require the plate, was the motor attached to the door and secure when you removed it?
- Nick
