Guest
Posts: n/a
My passenger side window stopped working so I pulled it apart with your detailed procedure, but I found a discerpancy - my regulator/motor assemply did not have the adaptor plate shown in figure 29. Is this possibly an omission by the factory or a subsequent incomplete repair? The failure seemed rather dramatic - the steel cable pulled apart. Might this have been caused by incorrect installation? If I need this adaptor plate, where can I find one? Thanks Gary
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The cable failing that way is pretty standard. Your vehicle may not require the plate, was the motor attached to the door and secure when you removed it?
- Nick |
Thread Tools | |
Rate This Thread | |
